OK... I have finished painting the '32. And although the clear went on what I thought was pretty good, I am having some trouble getting the little bit of orange peel out of it. I am wet sanding with a spray bottle with a few drops of dish soap, a soft block wrapped in 2000 grit.
I am knocking the peaks of the orange peel and then trying to follow up with 3M Perfect-It Rubbing Compound on a Wool Pad followed by Perfect-It Machine Polish on a Foam Pad followed by Perfect-It Ultra Fine Machine Polish on a soft foam pad. But when I am done I still have some orange peel. I even tried sanding again and getting close to the base of the valleys, but still had orange peel when done. What am I doing wrong.
Should I be sanding the clear completely flat (all the way to the valleys) before polishing or am I not pushing hard enough on the first pass of polish.
I am just deathly afraid of burning through to the BC. I have 3 coats of clear on it, but I am terrified of ruining all my hard work.
