Hi everyone.
I have narrowed down my engine choices to 3 different engines from 3 different shops. I will list each down below and let me know what you think I should go with. The car that gets this engine will be a 1980 Camaro Z28 fully restored. Here I go.
Engine #1
Chevy 350 410hp/428ft/lbs torque, 4 bolt, dome pistons 11.5, cam is 510+ hydraulic dual patterned, SS roller rockers, runs on 91 + boost
Engine #2
Chevy 350 440hp @5900rpm 450ft/lbs of torque @4400rpm, runs on 91 octane alone, 3.484 stroke crank, 5.7 forged big beam rods with ARP bolts, 10.1 compression flat top pistons, 4 bolt block, hydraulic flat tappet cam with .512 valve lift, dart/world/rhs heads 200cc intake runners 2.02int/1.600 exh swirl polished, heads have extra thick deck surface, 1.440 high performance springs, roller rockers, perfect circle rings, hardened push rods
Engine #3
Chevy 383 stroker, gm iron vortech heads 175cc intake 64cc chambers, eagle crankshaft, 5.7 long ibeam rods, speedpro flattop pistons with moly rings, 10:1 compression, comp cam 230/[email protected] with 480"lift, power range 2000-5500 rms, no roller rockers but they are 250 extra and stage 2 porting is 300.00 extra.
Let me know what you think would be the best buy. All engines I can have built for about 2700.00. Just trying to get the best bang for the buck. I just want a reliable build, that I can go to car shows with and also make a pass or two at the drag. Thanks Peter
Engine #1
Engine #2
Engine #3
