Hello I just sprayed Nason's epoxy primer 491-35 for the first time on my hood and tailgate.
-It appears to have a significant orange peel affect to it almost spotty looking in places like there was too much air. I sprayed it at around 30-35 psi. I sprayed 2-3 coats as I didn't want to make it too thick. *The guy who sold me the paint said that epoxy primers are known for this, so I was not too surprised.
-So what can I do to fix the orange peel affect? Can I wet sand it? What grit would be good to use? I was told that it is also hard to sand and clogs up sandpaper fast.
-I will be spraying a Nason sandable primer filler on top, so do I need to sand the epoxy primer smooth first, or when I sand the filler primer coat will that sand smooth itself regardless of the texture on the epoxy primer underneath it?
Thanks I am learning!!!!!!!!!
