I have had an issue since getting my truck back in January of 2008, the Qualcomm reads on the home screen under STATUS: **BAD 2000**, and hitting the "help" button on the keyboard displays:
Comm. Unit self-test failure
Replace Comm. Unit
MCT system needs servicing
Technician: Refer to MCT Diagnostic Guide
The truck is a 2007 model year Freightliner Century S/T 100 inch double bunk sleeper with LSD fuel emissions truck with 14.0 liter Detroit Series-60 engine and Eaton RT-10 trans with 3:58 gears and 295/85/22.5 tires, like half of that matters.
Possibly something to do with the black box under the bunk?
Also the latest issue I have been having with this truck is my gauges failing at just about any time they please, moreover lately when parked but a few times in the past while moving, thus setting a Hard Braking Event when they drop out like they do.
Reading my dash display when this happens shows:
ENG ROAD SPEED
Bad 128 084 12
It has done this on several occasions since mid 2008.
This newest problem with the gauges failing includes primarily the tachometer, oil pressure, & water temp gauges.
And the very latest in my truck gremlins beginning about 2 weeks ago the dash display reads the following when checked after displaying a flashing "ALERT NO DATA LINK":
ENG Controller
OPEN 128a254 07
Would this have anything to do with too much junk stored in the sidebox on top of and behind and around the black box in there, because after I removed all that junk and wiggled the wires to make sure they were seated or attached solidly, everything worked fine.
I have been through several different Freightliner dealers for this very problem, gauges zeroing out and setting an HBE event, and nothing being done about it except some doofus in Maintenance telling me how to reset the fault codes myself, and not documenting it.
OH yeah, and the next time a tech in a Freightliner dealer asks if I want anything turned up for free, I'll tell him my top speed to 65 and 1800 rpm's 6th through 9th.
Replace Comm. Unit
ENG ROAD SPEED
Bad 128 084 12
ENG Controller
OPEN 128a254 07
