I had to remove the heads on my chevy stroker. I replaced one of the heads with a new one. How can I set the valves without running the engine? I don't want the oil mess associated with running while adjusting. I was told there is a way to do it without starting the engine.
Thanks, Jeramiah
do you have a degree wheel on your engine?are you good at math? NOTE: there are valve covers that have sides but no top,this stops some of the oil splash for making adjustments on a running engine.
