I have a 59 Suburban with a transplanted 74 Camaro rear axle. The axle is posi with 2.73 gears. When I swapped it originally I had the pinion angle wrong. The pinion was angled up towards the front while the transmission is almost level. This resulted in some vibration at low speeds under mild acceleration.
After a year of driving it like this I finally was able to change the pinion angle to match the tranny. They are now parallel.
However, the test drive yielded the same vibration, actually a bit worse. It doesn't vibrate under acceleration but as soon as I let off it starts.
Also, a few weeks ago I started hearing some rattling during coasting at interstate speeds. I'm pretty sure the U-joints are OK. I can't get the drive shaft to move at all. So I'm wondering if I have a dying rear axle. It's old.
I'm in the Birmingham Al. are now but should be back in the Nashville area by Monday if you have a shop to recommend.
