i have a 1979 malibu 355 engine cola crankshaft.. manley rods.. wiseco pistons.. 194 gm heads.. victor jr. intake.. holley 4160 600 cfm carb.. proform geardrive.. accel dist.. hughes turbo 350 trans with hughes 3500 stall converter.. 373 full posi strange axels richmond gears.. my cam is a elgin 230 230 480 lift 110 center lobe.... my problem is im confused if my converter is trash or the carb or timing is way out of adjustment. after car is warmed up to 190 degrees. put in gear and step on gas peddal it will stall everytime. no vacuum leaks what so ever. the car moves just fine only until when given gas... ive had the car out a few times this summer but not too much due to broken windshield. how do i tell if its the converter or carb... changed acc pumps twice and put a 31 size squirter from a 25 size. idles fine and will rev like crazy but in gear stumbles every time
