Hey guys,
My Fatman mustang II IFS has been final welded in and I’m trying to get all the information I can before deciding which SBC (LT-1) motor mounts to use, and where to weld them. If given a choice, I’d prefer to use the stock motor mounts. My last project truck, I use the L shaped aftermarket SBC mounts, and although they utilized round rubber insulators, there was still more vibration than I would like to have had. I’m gonna have to do a fair amount of fabrication to secure the bottom part of a stock mount to make it work, but if I can position the engine in such a way as not to interfere with my rack and pinion connections, I feel I can make it happen. I need some input from you fellas concerning engine-positioning parameters. The lower firewall in my truck has been cut out, and will be custom fabricated after the eng/trans mounts are in place Here’s my questions: What is a “ballpark” horizontal distance between the oil pan “hump”, and cross member? What is the highest and lowest vertical distance that you would want to mount a SBC, relative to your mustang II cross member? Any, and all feedback related to engine mounting location will be appreciated! Thanks Jimmy
