Howdy: I'm wiring my 69 Chevy truck (93 GM 350 TBI/700 R4) with a Painless harness which includes wires to connect to a neutral safety switch. I believe one carries in power and the other one passes it on to the starter solenoid when the transmission is in park and the key turned to start. Unfortunately, the steering column I got from Tuckers at a great price, does not have a provision for a NSS.
I want some protection from starting in gear so I am thinking about using a relay that would be activated by the brakes being applied. I would use the #30 terminal for the power in, the #87 for the power out (the two wires in the Painless harness), the #86 spliced into the brake light wiring, and the #85 to ground. When the brakes are applied, current would be allowed to flow to the starter. It's not as safe as the actual NSS, but better than nothing.
Does my idea hold water, or should I wire it differently, or try something else altogether?
Thanks
Fleetsidebob
Thanks
Fleetsidebob
