i have a set of 487x heads. i am building a motor, it will have 9.5 compresion ratio. will the stock heads work with a comp 292 magnum with .501 lift will they work with this head? or will i need to have the guide cut down.
i allready have the cam in a short block but does the guides need to be milled down or do i just have to check them just to be safe? and whats the max lift i can run on these heads before the guide need the be cut down
