OK guys, I have a 67 elky with a SBC 350, mild build on the engine. Typical bolt on's, TH350, 4.10 gears, 3000 stall and a comp 286h magnum cam. I just put in a new MSD HEI pro billet distributor. I ligned everything up and installed the dizzy.
Upon firing it, I noticed the engine had a vibration that was not there before. I put the timing light on and the timing marks were barely visible, like they were not where they should be. Well, what I think I did was install the distributor one tooth off, because now when I rechecked tdc and looking at the dizzy rotor, the number one plug wire is one spot past (clockwise) where it should be, according where the rotor is now pointing. Now, I go to remove the distributor and It will not move, I can't budge it. I am letting the engine cool down hoping the metals will shrink and loosen up abit.
Any thoughts on why I can't get the dizzy out?
