Question from an electrical newbie....My wifes car ('97 Sable) has developed an electrical glitch over the last while in addition to all the others. This car has always been an elecrtical lemon....The washer pump some times works (for the last 5 years) as well as the drivers window and the rear window washer pump no name a few. In the last year the headlights began to flicker constantly and now the car has developed a random total power cut out during driving. (mostly during decelleration or braking) The cut out only lasts a second or two, enough to see the gauges go nuts, radio and lights fade and loss of ignition. (engine stumbles) There is sometimes loud clicking coming from the upper left corner of the dash when this happens. (my wife has even heard these clicks when the car is not running...***??) We had it at the garage and they lost all the data when it "stumbled". They replaced the ignition switch which solved the problem for a few months. Ironically (and I may have answered my own question) the switch has been starting to buzz like the key is in it some times (on exit or entry) untill you wiggle it, but causes no engine stumble or power loss when wiggling it as we are driving. Im thinking these two symptoms must be related as they started up around the same time.
Is ther anything else I should check? Computer, wiring harness short or loose connections? I wish it would just quit altogether so we can trace the problem...If it was only me driving it, I'd hope it catches on fire so I could walk away. (But for the safety of my wife and kids, Id like to see it fixed.)
I don't really care about the minor glitches like the washer pumps or windows, I'm primarily concerned with this ignition thing as I believe it is a major safety issue. Any advice is appreciated.
