1 - 13 of 13 Posts
· Registered
Badriand, thats up to you, you are the only person who knows what you like. You could ideally use nearly any color they offer and come out with good results, but only you will know if you like it. If your not daring any color within the spectrum of green(blue, green, yellow, gold, "white" or any shade therien) will always go nicely, it the safe way to go. If your more daring than most you could chose a off color like red, orange, or something like that, only you can chose because only you know what you like. I would chose a gold or yellow or white, but thats just my personal taste. Do what you like, not what others like.
HK
· Registered
Personally I'm not a big fan of purple anything so I would of course have to go with white. It all depends on how wild you want the truck to look. A white will give a frosted green look depending on how much pearl you use. Purple like I said I don't like personally, but on a green base it doesn't sound very apealing to me, but if you like it go for it. White would not be eye popping whoa type look, more like a subdewed smooth look, I think in your case unless your looking for something that is flashy, use white, but that just my opinion. Go with what you'll like, you have to look at it and drive it everyday.
HK
· Registered
Originally posted by badriand:
<strong>Just a white pearl shot about 2 or 3 times?</strong><hr></blockquote>
I would recommend practicing on something else first. I thought it would take much more than it did when I did my flames. I used 1/8 teaspoon 4 ounces of clear and just dusted on one very light coat with a detail gun. Pearl goes a long,long ways. I then shot three coats of clear over it.
I guess it depends on whether or not you want them to show all the time. I dusted a second coat of a different color over the tips of the flames and show more than the body.
Again, practice before you do the real thing or you may be unhappy. Remember that the pearl will show more out in the sun than inside under lamps.
Chris
[ December 19, 2002: Message edited by: TurboS10 ]</p>
1 - 13 of 13 Posts
