I have a 54 dodge pickup with a flathead in it,
supposed to be very fresh, twin carters on an Offenhauser intale, Phillips performance 3 into one manifolds, phillips performance breathers, Mild Cam, Balanced etc. etc.
the problem is, this thing falls flat on its face, timing is set at TDC initial, and reaches about 18 degrees total timing, Ive syncved the carbs using a unisync., replaced every possible ignition component..tried the timing all over the place...stumbles like timing is out, but it seems to hold rock steady, ...heres my question..It only has about 11 inches of vacuum at an idle ...peaks at about 15...is this too low? ive heard a solid running flathead should have 20 inches, but im not sure with the twin carbs and the cam...im wondering if the cam timing could be off a tooth, when i got the truck the timing was out, and the guy had adjusted as far as he could ..and it was still too advanced..I had to loosen the secong adjusting bolt under the distributer on the flathead dodge and move that adjustment in order to move the distributer far enough to get this thing in time. doesnt seem bad with no load... but with any load this engine falls very flat ...stumbles studders misses all over the place....any opinion would be very welcome
Thanks
Al
Thanks
Al
