hi i am working on a chevy 350 4 bolt main and i want to replace the crankshaft but the one that is curently in the engine is 10/20 if i buy a new one will i have to have it turned to the same specs or can i just install it with standard bearings thanks
You got a leaky spark tube...
Is there something wrong with your current crankshaft? Are you looking to stroke it? At any rate, if you put a new/replacement crankshaft in the engine then all you need to do is buy the corresponding bearings.
