if you still have the sticker with the rpo codes in the glovebox in the console it will have the G code for ratio on it
like GU6 for example
if you cant find the stamping code in the axle tube then youre just gonna have to remove the diff cover and look
thirdgen.org has the charts to show what axle ratios came with which drivetrain combos
84 was different than 82 and 83.. in which were 2.73 and 3.23
84 with L69 were commonly 3.73.. in which i have owned many of
whats in it now is anyoen guess though..
someone could have changed it over the years..
rotating the tire 10 revs while having someone count driveshaft revs would be the most accurate..
not a big deal what ratio is in the car as these cars with a v-8 were pretyt quick regardless of the ratio..
i have owned and driven all different ratios of these cars and i have never noticed any ral difference in quickness of them from 2.73 to 3.73 ratio.
the 84 with the L69 were the most common and billions were sold that year.
heres three, of many ive owned..
84 l69 700r4 3.73
the first tow i parted stripped and scrapped. the last one i drove a year and sold and was in indiana somewhere i last knew.
