i posted this awhile ago to see what this toploader came out of. now i took the top cover of just to see if it was a wide ratio or a close ration trans. what i saw it looks like where 3rd gear is its actually 4 th gear. sounds strange but take a look at the pic.so i did some research and found that in 77-78 they made a toploader that was an overdrive that used 3 rd gear as the fourth gear that was an overdrive with a ratio of .81. you ford guys, have you ever seen this trans. or am i just wrong. i might be this is the first toploader i took apart. it a rug-FP trans that i cant find info on.
thanks
Randy
thanks
Randy
