Engine: 327 CUI
Tran: 350 Auto
I located what appears to be a coolant leak on the right front top corner portion of the intake manifold (see attached pic).
I used photoshop to circle the leak in the color yellow, the leak drains around and down a small intake pocket near the front corner bolt! It leaks a very very small amount of fluid, not enough to drain the coolant!
The leak does not appear to be coming from the digital temperature sensor right above the leak!
What are the symptoms I should see or hear!? The cars seems to be running fine, idles fine at 185 temperature, but has begun to heat up to 225+ when driving.
Tran: 350 Auto
