1 - 16 of 16 Posts
two cups of tea
Ok so I have a quick question,lately I've learned to love bc/cc as I've had no problem with orange peel.Now today I shot a buddys car with some cheap single stage &I've gotten orange peel its not too bad but its there looks pretty minor but its through the whole car,
Now it was fairly chilly only about 65 is that my problem or was I moving too fast or top slow?it has a nice gloss but if I try to sand it out its so dull looking. What am I doing wrong?
Nova Guru
Sand it flat with 2000 and buff. When you sand it you want it to look uniformly dull like this quarter panel. Sounds like maybe you were moving too fast and it may have been a tad chilly both air temp and metal temp, also did you have your PSI high enough on the gun? Were you holding the gun close enough to your work?
Hopefully experts will chime in.
Andy
It could be a number of things
Too narrow of a fan
Not enough pressure
Not thin enough
Btw if its metallic you can't sand single stage, it'll marr metallic and then your paint job is ruined.
two cups of tea
&heres another thing so I hit it with 1000 grit wet&it'll make ot where its not gone but its flat...its like You can faintly see the pattern left behind.When I do that it gets the paint dull should I shoot cc to fix this even though its a ss or just re shoot the ss&if I do that should I shoot another coat of primer over it?Help me out fellas
Nova Guru
You need to get it down where you see zero shiny spots left (those are tiny low spots). If it were me, I would block it all down with 400 or 600 and reshoot the SS.
Sounds like you got heavy orange peel. I had this happen to me on the Nova I did and it was because of two things... fan was closed down and not enough PSI. It sucks.
Hopefully an expert will add to this discussion.
Andy
ambient lighting.
If you don't have enough light you can't see what is happening when you are spraying. I used to hold a trouble light in one hand and the gun in the other, probably not a good idea spraying something flamable but back then we rode with out helmets, no seat belt in the truck, and drank water from a hose !
two cups of tea
Discussion Starter · #11 ·
sounds like were from the same neighbor hood :)
Ive got tons of lighting Im thinking its the cheapo primer because I went&shot a panel with
3 good coats of high build primer&gun set up the same&no orange peel.Im thinking Im notbgonna shoot anything but bc/cc anylonger.When I shoot bc/cc I seem to come out fime but everytime I shoot ss theres issues...is ss really more prone to orange peel?Ive heard mixed feelings about this.When I was a kid my grand daddy use to use lacquers&he had a lot of stuff in shows...here's one Sorry its a b&w
And here he is
I inspire to be just like him..never gave me nothing. Even when I was a kid&I wanted a buck for some candy I had to work for it taught me a lot without him Wouldn't have had noone teach me how to be a man my mom described him as a sawed off s.o.b. anyways getting off the subject when he pops In ny head I tend to. ramble ramble on
pop&his buddy Ralph&some other fella they were in a m.c c together pop is the one on the right&Ralph is the big fella.I meet him once but he's supposed to be. a monster when ot comes to making things go fast....man am I off the subject.Sorry anyways Any more answers to my questions are appreciated
Nova Guru
I don't think SS vs. BC/CC is your problem. Just spray the last 2 coats of the SS as if you were spraying clear. Lay it on wet and it should look good provided your gun settings, distance, speed etc. are all correct also.
You'll get it.
Andy
put up or shut up
you're gonna end up with peel using the purple gun and at 65. The gun just can't atomize good. If you put in more reducer you risk runs and solvent bubbles. I'd do two wet coats and not worry about getting it to look like glass cause if you do get it to look like glass, as I said, you'll get solvent bubbles cause it doesn't atomize good. Not knocking the gun but if you have a good gun you'll get the glossy glass look but it will be atomized better so it's applied thinner and able to breathe. This is important when painting black.
Nova Guru
Don't know the answer. If you are convinced its the paint and not spray technique/ air issues/ gun setup, then you should probably wet sand the car again and use the clear that you said sprays good for you.
The SS will just become your "base".
Experts please chime in.
Andy
two cups of tea
Discussion Starter · #16 ·
Well I think its a few things now...first the generic primer,second my gun,I bumped the psi up to 60&it seemed to like that.Next I went&bought some primer from my local bobber&shot it on the cab of a 56 gmc we have after some lite body work&the paint came out nice&smooth on it.So cheapo primer is my guess
1 - 16 of 16 Posts
