jo5hi3 said:
the tps, iac, and maf are all brand new the only codes it threw was an 02 and that was cause it was unhooked. can someone tell me what my readings on all my sensors should be like iac and things?
it is impossible to run a computer controlled viehicle without an O2 sensor.
The car will not run once the ECM reaches a certain time after start. For 80's cars(g-body carbed) I know it was something like 5 mins it would run on a default setting, and then start follow what all the sensors said. I might be wrong on how much time it takes, but the car will not run without it knowing what the fuel/air ratio is.
Also what heads did you install? You can not up the compression without a prom/cam change sometimes.
Only sensor default I can tell ya for that car would be the O2 should be at around .675-.875mv while idling/cruising, and go up to .9XXmv while accelerating.
