here's the issue: trans is newly rebuilt. all standard parts replaced ie:clutches, seals, o-rings, gaskets, etc. trans has b&m shift kit installed. its actually a th-350-c, ya know, lockup converter(not hooked up tho) lockup not used pulled from a wrecked 87 scottsdale, 9"tailshaft. trans fluid normal. no leaks. manual valve is adjusted properly, governor working properly, case vent installed(shouldnt matter). now that thats out the way......trans when cold will take its sweet time engaging from park to drive, park to reverse, basically you put it in gear and it will start moving when its dang good and ready. once hot and been driving for a bit it will go from park to drive or reverse with no problem. now i have noticed that it seems to need more "gas" to move in reverse almost like theres lots of stall in the converter(which is 1800rpm btw). it shifts firm and fine, just finicky when cold. not sure if i have a valvebody gasket leak or the low/reverse piston is leaking down. maybe the direct drum piston is leaking down seeing as its not discriminating from foreward or reverse? just curious as to what is causing this. trans is out the car and i'd like to know what to look for BEFORE i tear it down. i did install the piston seals with a dulled out hacksaw blade which is why i suspect apply piston leakdown. other than leaking seals on apply pistons does anyone else have any good ideas? kinda stumped. thanks
