1 - 2 of 2 Posts
Hey Everyone, My name is Michael. I'm 21 yrs old, and I live in North Carolina where I'm a Career Firefighter in a town called Browns Summit. Anything else just ask.
I have a 1992 S10 and I'v recently put a 350 in it with a 5 speed behind it. 1986 Block. The bottom end is stock with flat top pistons. I had the rotating assembly balanced and the cam I have is a Blue Racer by Crane Cam. It has 224/234 duration at .050 and .465/.488 lift, Lp is 114.It is a hydraulic flat tappet. I have the edelbrock E-tec 200 Cylinder Heads which have 2.02/1.60 valves 64cc, 200cc runners. A performer intake with a A.E.D 650 H.O. Carb, and 1.5.1 Roller Rockers, and a MSD ignition System. 10.2.1 compression.
My Question is I need some Cam help. This cam performs fine but it has little sound it sounds stock when the engine warms up. and I want a lopey cam, but I don't really want to take the heads back off to check clearance. I was wanting to know if you guys knew what to use. Judging by the numbers I thought it would lope but it doesn't. Any help would be appreciated.
welcome Michael...Probably best to ask in the engine forum........
Are you running headers....I find that headers make much of the sound that we are usually looking for.
1 - 2 of 2 Posts
