1 - 2 of 2 Posts
hi guys im redoing my wiring in my 67 beaumont on the firewall there was a high current curciut breaker it was a 12v 40 a my question is is it ok to go with a higher amp and if so how hihg should i go i have my car as stock for now . thanks for any help.
The current rating of the breaker is dependent on the wire size it is protecting. In other words if your wire size dictates a max load of say 40 amps and you up the breaker size to 50 amps or greater then your wire becomes the device that will burn out. If the breaker is supplying voltage to your fuse panel it gets even stickier as the total load needs to be calculated. If you are having trouble with the 40amp breaker tripping you need to investigate why.
Vince
1 - 2 of 2 Posts
