This paper came with my high volume oil pump and it says this:
"The installed pink spring in the pressure regulating valve will allow the pump to bring the engine oiling system to equilibrium at approximately 70 psi. (Note: Not all engines are capable of achieving a pressure of 70 psi due to loose bearing clearences, or bearing wear, etc.)"
I was curious what this exactly means, is my engine supposed to get up to 70 psi? When I primed the engine the oil pressure would not go past 60 psi.
Thanks, Mike
Thanks, Mike
