holley 1/4 throttle to full throttle
511 Views 8 Replies 7 Participants Last post by  RAYFIN
If you ran the same ET at 1/4 throttle as you did at full throttle even though your rear squirters were squirtng and your throttle blades were opening {at WOT) would that mean that the rear metering block was somehow defective or maybe the incorrect one was installed? Used 700 double pumper 4778-3. The front block was marked 4778 but the rear was a 383-440 mopar number. Chrysler part # 3420374.
1 - 9 of 9 Posts
· Registered
You must be getting at least some fuel flow through the secondary jets or you'd have a massive bog when the secondary throttle blades are wide open, and you'd actually run faster on just the primaries. I'd soak the carb body and metering block in carb cleaner and blow out all passages for starters. Then again, maybe that Chrysler metering block is somehow not compatible with a standard 4778 carb.
On another note, has the engine run as expected in the past with another carb?
· Registered
Post a photo of what your rear metering block looks like and that could tell a lot by seeing it. If the rear metering block does not have the same emulsion ports like the front and same idle feed restrictor setup machined into the metering block then it would throw the secondary fuel curve off on the secondary side and cause some issues with mixture and stuff.
If the block is the same style metering block used in the Holley 4150 series carburetor for street use then it should be ok but I would at least want to check the emulsion port size to see if its matched with the primary. Most are .028 and have two emulsion port holes each side and one kill bleed each side.
· Registered
When an manufacturer that is making an end use product like an automobile, motorcycle, airplane, locomotive, etc. assigns their part number to a vendor of sub-components it is likely that the part so assigned represents a somewhat unique to that specific part by the end product integrator.
Therefore it is possible that some characteristic of the Chrysler part numbered Holley metering block is not compatible with other Holley carburetors even though it bolts on.
Even within Holley you can get into trouble mixing parts a good a example is square bore and spread bore metering blocks will bolt up but not all passages are in the same place.
· More for Less Racer
Back in the day (late 70s) the 4778 and 4780 Holleys were dogs and very unpopular. Maybe EricNova can address this?
Not that I ever knew of, they just seem overlooked by many so not as many sold, but there weren't any problems with them. 700 and 800 get overlooked because not all companies offer those size would be my guess.
I used an original 4780-AAS, the original roller link secondary design and it was a real good carb, then sold it to a friend and he raced with it for years.
I recall an 830cfm Holley that was unpopular, it was basically the bigger 850 main body with an smaller 800 baseplate to make it 830 cfm. It seemed to have trouble with metering clean below 3500 rpm
for the Op's problem,
I'm going to go out o a limb and say there is something not compatible with that Mopar metering block.....If the picture I just googled and looked at in the Ebay listing for that exact metering block is correct (guy has the original Mopar box too, so looks legit), ...then it is the source of your problem.
There is a third circuit or something in that block, I'm not familiar with what it is but I can definitely tell you just by looking at the cast shape that the block is incorrect. It likely has altered and/or additional air bleeds and passages and their locations....so passages may not even align with the main body even though it bolts up..
It's been so long since I looked at one, it may even be a reverse idle metering block.
Also, best I can tell it is a primary metering block, and not a secondary.
Packing materials Shipping box Gas Packaging and labeling Box
You'd be $50 farther ahead to just order the correct replacement metering block for that 4778.
· Registered
Great catch, Eagle Eye.(y)
· Registered
Discussion Starter · #9 ·
No all fresh stuff.
I did order a correct metering block, just haven't been back to the track yet. I also picked up a 3310-6 to try.
1 - 9 of 9 Posts
