Hello,
I have a 600 cfm Holley w/ vac secondaries (model 1850-1) on a 289. The car has a 4 spd top-loader tranny. I have reduced the jet size from 66 to 64 (b/c of altitude) and have a #31 accel pump squiter with tubes/horns in it--the original was a #25. Since the car was always running rich and the primary butterflys were open too much, I drilled one 3/32 hole in each one. Now the car doesn't run rich, but is bogging when starting to move. If I slip the clutch quite a bit and rev it up, then it does ok. The car is rather high geared, not sure exactly what ratio.
The question I have is, should I start looking at accel pump cams or a larger squiter? I am on a bit of a budget (I am a teacher), so I don't want to just start buying parts.
Also, the car bogs when the secondaries open for a moment, then runs fairly well. I have bought a spring kit, and currently have the black spring installed w/ the ball installed as well. It got better w/ each spring, but the black one is the last one--any suggestions?
