Hi guys,
I have a holley 670 avenger on my 351 Cleveland, which is a standard motor and auto. I have removed my 2 barrel manifold and motorcraft 2 barrel carby as well as the standard points distributor.
I have fitted an edelbrock rpm air gap manifold, the 670 avenger and an electronic distributor. Distributor has been graphed and set up to 12 degrees.
When I open the throttle at low rpm it stumbles sometimes to the point where it almost stalls. It feels like it accelerates fine (like the squirter is ok) but once it has squirted and reaches the throttle position it then stumbles.
I have read the Other thread "Holley hesitation" and I would say it is the exact same thing as what I am experiencing however, I have the 670 not 570 avenger.
should I be able to get this carby to run fine given it is effectively the same as a 600 just with the secondary metering block and is a standard motor?
Should I just be able to play around with the powervalve etc?
I will put a vacuum gauge on it tomorrow to see what's going on there...
