1 - 10 of 10 Posts
Hey guys. I have a mild 350 sbc in my street rod. Really do not know the specs on the motor. But it is no street demon for sure, just a simple cruiser. I installed a 750 double pumper on it, basically because it looks really cool. It came with #74 jets. Had a hesitation when feathering the pedal. so I dropped it down to a 66. Way better but still not enough. dropped it down again to a 64. Even better but again not enough. decided to use a 60 but the store was out of them and only had #56. Does anyone think that that would be too small? Not a big deal to change them out but I really do not have much time these days. Would like to be done with this issue.
You need to be careful. Those are big steps and if it gets to lean you will burn the tops off the pistons
replace the power valve if its a used carb,use 69s in the front as a starter.
Is the carb new or off something else?
The carb is actually brand new. I have no idea about the power valve but the float site window looks to be about 2/3 or so.
lower the float so that it just barely trickles out the hole when you shake the car.Make sure fuel pressure is 5# or less.dont change Pv. your float level is way too high
Thats not a try it thing,,,its how you set up the carb. It should have come with basic directions and tune up specs? post a video when shes runnin good
Hesitation when moving the throttle open is a accelerator pump adjustment change, pump cam change, or pump nozzle change, not a jet change.....you are already in dangerously lean jetting territory with the 10 sizes smaller #64 jet.
750 Holley should never need more than 4 steps leaner or 6 steps richer jetting, unless it is a blow-through turbo or supercharged application.
Make sure float level is correct first.
For starters that 750 is really too big for a mild street motor. A 600 is a much better way to go.
Anyway...............check the accelerator pump adjustment. It should anywhere between .015-.020...............it has to be set a WOT(wide open throttle) Get a Holley book or just look it up online on the how to.
1 - 10 of 10 Posts
