First off sorry if this gets long, I just want to be thorough to avoid confusion.
Car is 1977 corvette, weighs about 3,400#'s
350 chev, bored 30 over to a 358, flat top pistions
Trick flow bolt on heads
Comp cams 122-122,(230 dur. & 480" lift) Has 1.6 full roller rockers
3000 stall and 390 rear end
Perf RPM AIR GAP intake, 1 7/8" full tube headers
Holley 750 dp, mech secondaries, no choke tower, 50cc accel pump
Vacuum at idle is around 8-9", goes down to about 5" in gear, Power valve is 6.5 (i'm sure to big), primary jets are 73, and primary squirter is a 40.
Initial timing 18 deg. and 34 total all in by 3000 rpm, no vac advance.
Took it out for a test drive after full warm up, motor ran fine through the gears but once I slow down and come to a stop, its chugging and sounds like its flooding, I'm sure it was cause of the black smoke.
The problem always seems to be after its been running a while, after full warm and then out on the main road. If I cruise it around the neighborhood and drive civilized it seems fine but once I get the rpm's up and cruise up to 50-70 mph and then slow back down I start to see all these issues with it wanting to stall out?
You guys all helped me out earlier this year and I'm very thankful.
Any advise would be greatly appreciated.
