1 - 7 of 7 Posts
Banned
Fellas,
I have a 750 vac. secondary carb in my garage that I am goiong to be selling. I was working on it and had the vac. diaphragm cover off to verify which spring was in it. A little ball bearing fell out and I have lost it. I can't seem to find any info in manuals or books that tells me what size it is, is it metal or plastic, and what it does. I think is a check ball but am not sure. I don't want to sell the carb to somebody and not have it complete. Anybody got any ideas about this?
WFO
cool rockin daddy said:
Fellas,
It's a 3/16" steel check ball that is there to act as a kind of damper so the secondary action isn't too abrupt.
WFO
Thanks Cobalt. 3/16 steel. Perfect. Just place it in the bottom and seal it up?
That's it! ;)
BTW, the check ball isn't supposed to seal perfectly, otherwise the vacuum can't get to the chamber above the diaphragm to actuate the 2'ndaries. Also, don't forget the little cork seal between the housing and carb body that seals the vacuum port.
A tuning aid, is to use different balls (smaller, or aluminum, etc.) and/or to purposely "nick" the check ball seat to allow a larger orifice to affect the rate and timing of the opening of the 2'ndaries- beyond what can be done w/just the springs.
Google "Tunnel Ram 406"
cobalt327 said:
That's it! ;)
I used an old hot rodders trick. I would use a Phillip screw driver that will fit in hole and tap it with a small ball pin hammer and this added four grooves. This will let more air to bypass the check ball. :)
1 - 7 of 7 Posts
