I've seen Holley heads mentioned before so here goes. I picked up some used heads for a mild build and was wondering what spark plugs I should use. The part # is 34R-12111. I think. If anyone hase some specs for me that would be great!
They use the typical 14mm, .750" reach gasketed plug most all aftermarket aluminum heads use....Autolite 3924 for example, or NGK R5671A-5, or -6, or -7.
You can cross reference to any other brand off of that.
With NGK, the higher the dash number at the end of the string, the colder the plug...-5 is stock heat range roughly, -6 aznd -7 are common naturally aspirated performance use, -8 or higher for turbo, supercharge, or nitrous applications or endurance running.
