I have researched this to death, but can't find a good explanation for this adjustment.
There are a lot of people who insist the primary butterfly must be adjusted so that a small portion of the transfer slot is below the throttle blade at idle (about 0.020" so it appears as a "square"). In fact, many go to the extreme of leaving it there and only adjusting the secondary to get their idle rpm.
Now why would that matter? I can see if the throttle is too high up and too much of the slot is exposed, you run out of transition metering during light cruising. But I can't really grasp why you need "some" slot showing at idle. There is the idle discharge hole to feed the enigne, and it seems to me that if the idle is adjsuted and the throttle blade windes up between the idle discharge hole and the transfer slot (so no slot showing), it should work OK.
And the reason I am asking is that an awful lot of info states how important this idle/transition relationship is to prevent hesitation/boggin etc. They must mean light accelration, but they don't seem to be talking about that.....they seem to mean "stepping on it".
In fact, as most people have a heavy foot when it comes ot accelrating, the throttle goes way up past the top of the transfer slot and accelration is based on main metering (jets and PV) with the accelerator pump covering things until the main system starts flowing. So how does showing the transfer slot "square" affect "stepping on it"?
None of my Holley books mention having the slot showing as a requirement, but do mention it as a bad thing if too much slot is showing.
I'm confused. Can anyone offer an explanation for this "square" slot requirement?
ps: I'm thinking of it with the only Holley I am familiar with, the 4160 vacuum secondaries.
