Hello guys I have just bought a used holley carb from ebay to restore and this is the first time I have come across the main body having some threads that are damaged. The main body is a standard 600 holley main body 4 barrel 80457 and the normal 12-24 thread size. Now my question is I watched a video by BLP on youtube on how you can fix this with there kit but I don't want to spend a fortune on a kit and I do have a tap kit and the proper drill sizes and stuff and also I have a perma coil 12-24 thread repair kit I got years back just for this occasion but I guess I never noticed they have different length coils. Mine are only .200 long which I don't think will be long enough for the fix.
Can anyone out there by using a bottoming tap to thread for the helicoil which I have the proper tap size for the helicoil but I don't know what length of 12-24 coils I would need. I see a common size like 1.0 then 1.5 etc and I don't know what would be correct. Can anyone who has done this fix before let me know and also I saw a video by jegs and they did not use a countersink bit like BLP did in there video and is that really necessary? I have a drill press but Jegs in there video just used a tiny hand drill to drill out the old threads.
This main body is aluminum and the threads are not all stripped out but some threads did come out on the bolts as the carb looked nice and clean on the outside but wow what it looked like inside was horrible. The accelerator pump was as stiff as a dead body and the spring was sticky and rusted from old gas and never saw one like that bad before. This will be a new lesson for me to learn but I don't want to ruin it as I paid a hundred bucks for this carb and they listed it as not damaged and just needed a refresh. Wow that was way off the description part.
Thanks guys.
Thanks guys.
