I guess the engine is still assembled.oldsmo said:As the title says I am trying to clean them up a little before I throw the new cam in. I was going to buy a small ball hone from snap-on. What size hone would you use or do you use?
Thanks,
Josh
If you are talkong about a Chevy and all of the SBC and the BBC I have worked on the liftes have been .842 and if you are talking about a Ford they are .875 just let the Snap.xntrik said:I guess the engine is still assembled.
If they fit freely, I wouldn't worry about it.
GM lifters are about 3/4 dia. (.742)
use 7/8 inch, easy does it, just a quick spin. All you're doing is knocking a little varnish off if the block has not been machined.
I've even used a brake cylinder hone for a couple light-quick passes after shop shot blasted block.
Remember all that trash, grinding stone particles are going down into the engine.
If there's no crank in the block, I'd shoot some carb cleaner in there, wipe, and oil them. You MUST get all the oil and grinding gunk out of there before installing lifters.
CNC BLOCKS N/E said:If you are talkong about a Chevy and all of the SBC and the BBC I have worked on the liftes have been .842 and if you are talking about a Ford they are .875 just let the Snap.
As I am guessing here as you did not name what engine you have!!!!!!!!!
Yep You was close but only .100 off it suks to get old.xntrik said:I got 2 out of 3 numbers right.
Doggone it..... that brain frag thing again......... thank you SIR :thumbup:
sorry about that.. SBC -Thanks for the replies everyone-CNC BLOCKS N/E said:If you are talkong about a Chevy and all of the SBC and the BBC I have worked on the liftes have been .842 and if you are talking about a Ford they are .875 just let the Snap.
Hey x,xntrik said:I guess the engine is still assembled.
Ah, didn't I say that?????? I wasn't trying to write a book here.killerformula said:Hey x,
When you hone the lifter bores aren't you stuffing some of the grit into the oiling holes on the side of the bore? How do you go about cleaning those?
K
I really doubt using a blue berry hone or a brake cylinder hone you could take enough material to over size a lifter bore as they are just finishing tools not sizing tools like the Sunnen lifter bore hones we have in the shop for .842 .875 and .904KULTULZ said:The bores need to be true and clean to allow the lifter to rotate freely. It is also true that if if one gets carried away and hones out of specs, oil pressure will suffer and it is possible for the lifter to c-o-c-k (guess they have had trouble with that word...) in the bore(s) and cause further valvetrain problems.
If just replacing camshaft, care must be taken to not allow filth to reach the cam bearings or drop into the pan.
