1 - 20 of 23 Posts
· Young and learning
Hey guys, new hotrodder here.
I bought my first classic car, a 69 corvette. Total project car. Has a 350 in it, don't know much about how it's built internally but it's a 010 block that's pushin about 140-150 psi compression w/ 461 heads.
Somewhat of a ways down the road but I'd like to put sidepipes on the car. However, I've read elsewhere that the quiet mufflers kill horsepower. Do any of you guys have any experience with this system, and which mufflers provide a good compromise between noise reduction and power loss?
Thanks for your time.
· Banned
I can say is this, you only want side pipes until you get sides pipes. Then you burn your legs getting in and out of the car...
As for quiet mufflers killing horsepower, its more complex then that. There are a lot of factors that go into play when it comes to car exhaust affecting performance. Like tubing size, crush vs mandrel bends, header vs manifolds, muffle size and type just to name a few.
I'll leave others to giving a better and more detailed answer as I'm not the best when it comes to exhaust.
· True Hotrodder
I loved the sidepipes I had on my '66 Vette. Sounded great, looked good and I never got burned nor did any of the gals that road in the car. I think that's one of those urban myths. And the other comment is correct, they are baffles not mufflers. I am not sure what the flow rate was but they sure didn't slow down my little 331/4spd combo. Damn - wish I had never sold that car.
· Magazines have “ISSUES”
Burning legs and extremely hot butts were the norm.
You don’t need to worry about muffler design with side pipes. You don’t have mufflers. Just baffles in the pipes.
That is nonsense .... side pipes do not run as hot as the collector, the further down stream the cooler the temps.
@ chasracer
You are exactly right, same experience here with a 67 coupe :thumbup:
Side pipes can have augers, baffles, and believe it or not mufflers.
I personally prefer just a nice big open pipe, from header to exit.
And another HotRod, 32 truck with side pipes. Real men drive side pipes................. LMAO
· Registered
My wife’s uncle is building a dodge brothers Truck rat rod powered by an old industrial HEMI and set up his exhaust much like your picture. His side pipes are 3” tractor stacks off of a John Deere tractor Which come out right behind the cab. He was going to run them open, but opted to slip a glass pack inside the stack so that it won’t sound like a tractor.
The old industrial HEMI is cool, but it is a low compression constant duty engine off of a water pump that he converted to run on the street. I don’t think it would sound all that great if left open with no baffling at all.
The pic attached isn’t his, but is very similar.
· Registered
The amount of streetable horsepower that your going to loose is not even worth thinking about. Run a 2.5" cast "Corvette " ramhorns feeding dual mufflers and you will be good.
You dont need headers or a x pipe. It is a looks thing that is it. If you want side pipes then run side pipes just hide a muffler inside the heatshield.
Street rpm we are talking about never going above 3500rpm on a 250hp sbc.
You can dump $1000 into headers and straight sidepipes and may see a 10hp increase at 3500rpm over the simple cheap easy to work on and run setup I listed.
Until you get above 350hp most factory style dual setups are up to the task for street driven rides while giving a sound that won't set off car alarms each and every time you pull into a parking lot.
Been there. Run a 2.5" system with a idle you can talk to each other in front of the car and you will be good.
Discussion Starter · #9 ·
Thanks for the responses, guys.
In hindsight, I should've used the term "inserts" instead of mufflers, especially since the kit in particular that I had in mind (which, in my late-night state of weariness, also forgot to mention) was a Doug/ Hooker kit. Not sure if this will change anyone's answers.
As far as heat goes, they do sell heat shields for these pipes. If that ain't enough, I can heat wrap them, too.
Sorry for the lack of detail in my initial post, guys. Also, again, I greatly appreciate the responses. So far from what I've gathered, for my application, it looks like horsepower loss really isn't anything that I should be concerned about.
Discussion Starter · #10 ·
Its interesting that you suggest that. A personal friend of mine said something similar regarding running cast manifolds.
· More for Less Racer
IMO, nothing beats the look of the big 4-4.5", no heat shield chrome Hooker sidepipes on a C2 or C3 Corvette.
My stepfather has the chromed Hooker headers and the matching collector sidepipes on both his resto-mod '64 Vette and near completely stock "Day 2 mods" '69 Vette.
The '68-72 chrome bumper C3's look especially naked to me without them...and I've seen a few with a cheaper Thrush(I think) 3" with heat shield type that don't include a matched collector header and they look cheesy to me, like a '70's Van craze look.
Discussion Starter · #13 ·
headers for sidepipes are different. Some road race headers are very long and pass where the sidepipes need to connect. 3" sidepipes are loud. No X pipe also makes them loud
What kind of headers do you have and what size
Not even sure what headers these actually are. I know they're a very old set of long tubes. But they've been on the car for a very long time; I suspect one of the previous owners built this engine in the 80s or possibly the 90s. Probably raced the car circle track, too.
That being said, the complete hooker kit includes a set of headers specifically for the side pipe tubes, so what I have right now really doesn't matter anyways.
Discussion Starter · #15 ·
Normally, I would. Both the Hooker and Doug kits have a Ø1.875 x 46" primary going into a 4" collector. Now I'll be the first to admit, I'm new to this stuff, so I'm not an expert by any stretch. But based on what I've read in HP Books's How to Hotrod a Small Block Chevy, that seems a little big on the diameter and long on the distance. Only option if I want to go that route. Otherwise I either go Cerial's route (admittedly I'm not a huge fan of the factory repro pipes, they just don't look as racey) or just run a traditional system.
All that being said, let's entertain for a moment that I bought a Hooker or Doug kit. Which muffler inserts should I run if I'm looking for a good compromise between noise reduction and top end power loss?
Absolutely, seeing the header tubes collect and enter the side pipe, is KILLER.
· 47 Plymouth Special Deluxe
Urban myth? Not quite...I had Hooker sidepipes on my 63 Corvette; they looked great, sounded great, but could be lethal if you're (a) not wearing long pants and (b) not paying attention getting out of the car after a drive...and I've still got the scar to prove it. Trust me, it did not tickle.
Discussion Starter · #20 ·
461 heads on a street friendly cam and 87 gas I am guessing it is in the 250 to 300hp range.
Thats probably about what it makes. I don't know much about this engine, as it was put together when I bought the car. What I do know is that it's a 010 block, likely a 2-bolt since it's out of a 1970 passenger car. Long tube headers. Went out and measured them, the primaries are Ø1 5/8. I notice that the heads have 202 stamped on the fronts and backs of the "camel humps" but I've yet to tear the engine down to verify if they truly are 2.02 heads or have any sort of porting on them (it runs just fine, why take it apart?) Vintage holley single plane street dominator spread bore manifold, I believe it's a 701R1-3001, and it's topped with a Holley 6210 carburetor. I run it on 91 octane to be on the safe side. Ignition is an old school Hays breakerless points conversion system. It doesn't have a big enough cam that it idles rough but it does have a little bit of lope to it; just enough to be noticeable.
Only data on compression I have are my 140-150 psi recordings with the tester but I haven't actually looked at the pistons to see if they're flat tops or not.
1 - 20 of 23 Posts
