1 - 12 of 12 Posts
Hey HotRodders,
I was on here earlier looking up how to build the cheap made in mexico 350 V8 and seen how big the gain in horsepower was with the ported Vortec heads, intake, and Holley carb. I realized that i have a Vortec engine thats in great shape so ive decided to build this block for my S10 V8 conversion. I was wanting to know if anyone can give me an estimate in horsepower if i use a Big Mutha Thumpr Cam from COMP Cams, ported Vortec heads, big long tube headers, Flowmaster 44 mufflers, Edelbrock Performer RPM intake manifold (Dual-plane, High rise), and a 750 CFM Edelbrock Performer Carb (calibrated for performance). The camshaft has an RPM range of 2600 to 6800 and the valve lash is listed below:
Intake Exhaust
Duration 291 311
[email protected]" Lift 235 249
Valve Lift 0.573 0.558
Lobe Lift 0.338 0.329
I will be using the recommended kit from COMP Cams and the compression ratio recommendation of 9.5:1. I haven't decided on the type of ignition system as far as the distributor goes so if anyone has any suggestions that may work with this application feel free to let me know. I apologize for writing so much for the first time.
Matt
Discussion Starter · #2 ·
It is a Gen III LS1 engine i believe. It was in a 1997 Chevrolet Silverado 2500 4x4. The casting numbers for this block is 14093638. After i google the casting number on the back of the block it says its a 5.7L Vortec. The heads have a 64cc chamber. The valves are 1.94/1.50 but heads are machined to accept 2.02/1.60 valves. Not sure what that means. The 9.5:1 compression is their recommendation. I thought about bumping it to 12.5:1 CR. I already have the pistons if i do the higher compression. Again im not sure if i even want that high of compression. Thanks for your response.
UPDATE!!! After a quick research ive learned that i have the 64cc TBI heads. Shouldve known since the engine is a TBI. I didnt get to look for the casting number BUT by the casting marks on the outside of the head i see the double bar. www.crankshaftcoalation.com says the casting num. is 193 and even has pics. This head is not recommended for high RPM performance unless serious port work is done. Anyone know what kind of port work would need to be done to make these work?
you said that you have an LS-1 engine.
Those engines are over 300 HP and fuel injected,with the GM hot cam and cleaned up cylinder heads they make over 400 HP with fuel injection.
Spend the money to make the factory FI work in your car and have an easy 400 HP engine that idles smooth and gets decent mileage,or convert to a carb and make less power?
www.generationhighoutput. com
Never mind the truck is a 1997 Chevy C/K 2500. It comes with a 5.7L V8 that is Throttle Body injected.
As said before: No, it's not. There was no TBI 96+ Pickups, nor are 193 heads off a 96+ engine. Your top end at the very least is model year 1995 or older for a truck. You may be confused because you're getting back about as much misinformation as you're giving.
96-98 was Gen I Vortec, not TBI. The head casting #'s should end in 062 or 906 for the 350 and 059 or 520 for the 305. Gen III Vortec truck engines were 4.8L, 5.3L, and 6.0L.
TBI head casting # ended in 193. It makes a nice paperweight.
1 - 12 of 12 Posts
