I know I've posted a similar thread in the past, but a lot has changed with this motor since then. If anyone would be able to provide an estimate of the horsepower and torque this engine will produce that would be awesome! This is going into a 1978 GMC truck with a TH350 w/ shift kit and 3.08 gears that weighs about 5,000 lbs. Here are the (pretty much) full specs:
Block: 1990 L05 350 (#10054727) bored 4.030" and decked to .015" piston/deck clearance
Crank: Stock ground .010 .010 under
Rods: Eagle forged steel 5.7 inch 5700BPLW
Pistons: Speed Pro H345DCP30 4.030" 6.9 cc valve relief
Head Gaskets: Clevite Nitroseal 5746 4.125" bore .026" thick
Rockers: Summit 1.5:1 roller tip poly-lock steel
Heads: Summit Racing SUM-152123 72cc Chamber 165cc int. runner and 2.02 1.60 valves. Same casting as Dart Iron Eagle s/s 165. Flow numbers for Iron Eagle heads w/ 1.94 1.50 valves (thinking the 2.02/1.60 will flow a little better):
-------Intake Exhaust
.200" 116 95
.300" 161 126
.400" 195 135
.500" 210 138
.600" 208 139
.700" 210 139
Compression ratio: 9.29:1
Camshaft: Comp Cams XS256S solid flat tappet 218/224 @.050 and .465/.477" lift
Intake: Edelbrock Performer 2101 dual plane
Carb: Edelbrock Thunder AVS #1805 650 CFM manual choke
Exhaust: Hooker Competition 2452HKR full length headers w/ hooker full 2.25 inch dual exhaust and 2.25 inch magnaflow straight through mufflers.
I'm looking for around 350 hp and 425-440 lb/ft torque and I hope this motor is capable of that. Please let me know. Thanks for all the help I've had in building this motor and it's getting close to being finished and started for the first time. I really appreciate your advice on this engine although parts changes probably can't happen at this point as I have most of them already installed.
.200" 116 95
.300" 161 126
.400" 195 135
.500" 210 138
.600" 208 139
.700" 210 139
