I have a 80 gallon Sanborn air compressor that is blowing hot air from one of the intake filters ( there are 3 pistons each with there own air filter) I was doing some sanding in the garage and I noticed it kept running and my pressure was a little low. It usually gets to 150lbs in under 5 minutes. But it was hovering around 100psi and had been running constantly when i moved my hand past the air cleaner housing and it was pumping out hot air at a pretty fair rate. The compressor is only 2 years old, and I did some light painting with it a year ago and i just run basic hand tools with it on a semi average basis. What gives ? Did a cylinder burn up?? The other two are sucking air and running cool, this cylinder is pretty hot. It has plenty of oil which I can see thru the sight glass and is fresh.
