This has been an ongoing problem for some time, and I thought I had it fixed. Well.... Since I built my 383 about 5 years ago, I had some similar problems, but after discovering that my 6 month old Optima Red Top was slowly dying, and then the starter started losing "torque', I bought a new gear drive starter, all was well, but then the original HEI ignition module would "die" when hot, then come back to life when it cooled off a bit, so I bought an MSD "HEAT" HEI module, and all seemed well for a while. (NOTE: It's curious that a few minutes ago, I looked at the same module that I bought on Summit, and it's no longer called a "HEAT" module. It's called "High Energy". )
So here's the problem now. When cold (75 degrees, first start), she cranks up and fires off sometimes instantly, not even one revolution. Cranks fast too. As the engine heats up, depending on the temperature gauge, there is nearly a linear relationship between the temperature and ease of starting. She cranks a little slower as the temperature rises, and cranks longer before it fires off. By the way, my fuel pump is mechanical, but I have installed an electric fuel pump and a push button on the dash to negate vapor lock after a hot shutdown, which works just fine for that particular issue.
So yesterday, I received my new four port thermocouple electronic thermometer (I know, Chinese)... which is squirrelly as hell, and inaccurate. The plan was to tape down the probes to the radiator water supply and return, the trans cooler input, trans cooler output (fluid to air finned coolers in front of the condenser), to be able to mentally connect what my temperature dash gauge says relative to the actual temperature of entering water to the radiator. So I cranked up and drove it a few miles, came back home and sat there idling with the air conditioning running, hood closed till the dash temp indicated rather high. (appeared that water got up to 230 degrees, at about 90 degrees ambient). After taking the readings, I shut her down then tried a restart. cranking slow, ... pushed the electric pump switch, can hear it running... for about a minute... no fire..cranking slowly and battery started running down till I gave up....
So here's a couple of questions for y'all experts.. at present, I don't have an ignition tester, so what's the best/easiest tester that may indicate a weak ignition voltage?/ Has anybody had any bad experience with the MSD "HEAT" module? How affected are starters to heat? My battery and Ford type starter solenoid are in the trunk, with 1/0 welding cable to the starter. Starter is wrapped with aluminized fiber heat shield (header is about 1/2" from starter)...
I know, I should be able to figure this out. But advice never hurts. ....
