hi whats up guys me and my friend are getting into drag racing we are gonna run street class, in this class there are weight restrictions and a maximum CID of 360, we are gonna run a 1977 firebird, we have already lightened the car as much as possible and installed a roll cage, we are now about to build the engine we already have all the parts, weve bought on a budget mostly on ebay and buying from friends, see what you guys think about our engine setup, early 70's block 2 bolt truck block, hot tanked, magnafluxed and bored .040, crankshaft is a scat forged peice, rods are also forged light weight, pistons are speed pro hypereutectic with .125 dome, (rotating assembly has been balanced) camshaft is a crane saturday night special adv dur 294 degrees intake 300 degrees exhaust 502/516 hyd flat tappet, crane lifters, comp cams hardened pushrods guideplates and comp 1.6 roller rockers, the cylinder heads are dart iron eagle 200cc intake runners, 2.02/1.60 valves 72 cc combustion chamber, 3 angle valve job, victor Jr intake, with a 750 holley HP carb, we havent decided on the ignition system yet but more than likely will be MSD, exhaust will be big tube, long tube headers, with just turn outs (so open exhaust) we will be running an electric water pump. electric fan, and an electric fuel pump, and no power steering, we will be running 110 octane fuel, as for the rest of the drivetrain we have a TCI powerglide with trans brake dont have a converter yet probably gona have one made because the weight of the car probably around a 2,800 stall, rear end is a 9 inch ford full spool 31 spline axles and a 4.88 gear, sorry about the long drawn out info but its need to give me an adequet assesment of our car, what kind of power can we expect from the engine, and what kind of times do you think we might see on a 1/8th mile strip, thanks guys
