87 Relays almost never fry. I have submerged, frozen, and melted them and they still work.
You run a 30 amp fuse from the batt or 12 volt power 10 gauge wire to the relay.. 30 amp to the 30 post. Works nice.
You run the 5/10 amp from the thermostat switch to the 86(signal)
You run a 2nd 5/10 from the over ride switch to the relay 86(signal) also
87 is your 12 volt output to the fan
85 is your 10 gauge ground
All the 86 is doing is connecting the 30 and 87 terminals so 86 can be a lighter gauge wire/fuse.
I like to run headlights and fan relays directly off a dedicated battery post using ring terminals and a wingnut on the battery post. It saves wiring and keeps things clean. I have the fuses inside weather proof holders. Located close to the relays yet out of sight like tucked into a inner fender hole behind a piece of trim or on the side of the fan cowl up high.
