I'm sure most know the signs of a bad cam. The excess valve noise from the extra clearances, engine running rough, pushrods not turning, and so on. However I pulled a cam out of my 406 last year that had only one bad lobe. It had at least .050 material worn off, however you could never tell it from the lifter. All 16 lifters looked the same and appeared to be perfect. The engine didn't miss either and I didn't hear any ticking from the valvetrain. The cam had maybe 300 miles on it, it could have been in the infancy of it's failure.
All of this is leading up to my current cam. I have a XE284 cam in my 406 now and my engine has always had a miss since installing the cam. I've checked and replaced everything but the cam. I had the intake off a few months ago and I pulled each lifter out and looked at the bottoms. They all looked great. However that doesn't mean anything since they also looked good on my other cam. All of the pushrods spin when the engine is running. I can hear a very mild ticking, but it could have always been there or could be an exhaust leak. All of the rockers move up and down when the engine is running. However there could be a couple that aren't moving as much as the rest. You can't tell by eyeballing whether a lobe is worn down a little more than the rest.
I don't have a good enough dial indicator to measure my lift on the pushrods. It looks like I may need to pull the cam and measure each lobe. I had thought about pulling the intake and then try to view the cam lobes thru the lifter bores. thats not real accurate, but it may work. I didn't need to measure the lobes on the other cam to know they were bad. They stood out like a sore thumb. I guess with the intake off I could measure how far up each lifter raises.
Any help or advice would be appreciated.
