Hello,
I'm closing in on the body work and will prob be painting within the next month. My thermostat usually in the winter doesn't get below 50 in the garage. Other than that it stays around 50 to 55 without heating.
My question is if i heat up the panels with a heat lamp, will the outside air maybe around 40-50 degrees allow my paint to cure?
I set up a positive pressure make-shift booth so it will be blowing in the cold air. Thanks
Chris
Chris
