bigrobdog said:
It is a method to assure that the current flowing thru the generator and regulator is going in the correct direction for the vehicle.
To polarize the system:
Before cranking up the engine, hold (do not permanently connect this wire. Just hold it in your hand) a jumper wire from the 'B' Battery terminal on the regulator to the 'A' armature terminal on the regulator for a few seconds. Remove the jumper wire.That's it. Everything is completed. The system is now polarized.
This is why the system needs to be polarized:
Many early 6 volt systems were positive ground. Some were negative ground. Some later 12 volt systems were also positive ground. Today most are negative ground.
When a DC generator has been taken apart to be inspected and/or worked on, there is a possibility of the polarity being reversed. To insure that the generator matches up with the vehicles system, the armature/regulator must be "polarized" with each other. This is done very easily and simply. See instructions above.
Connect all the wires in the correct location. From the generator to the regulator it is 'A' (armature terminal on generator) to 'A' (armature terminal on regulator), then 'F' (field terminal on generator) to 'F' (field terminal on regulator). The main body of the generator is grounded to the engine. The outer shell (body) of the regulator is grounded to the body thru the mounting bolts. There is a #10 gauge wire that goes from the Battery 'hot' terminal to the 'Battery' terminal on the regulator. The connection at the battery will depend on whether you have a positive ground or negative ground system.
SEPARATE NOTE:
Systems that use an alternator do not need to be polarized. An alternator produces AC (alternating) current. This is changed to DC (direct current) by diodes inside the alternator.
