350 .40 over how many cubic inches?
and easier to do on a cheap calculator since you don't have to remember and re-enter any numbers.Blazin72 said:Another way to figure displacement is Bore x Bore x Stroke x # of cylinders X .7854
It does the same thing that farna showed you but for me it's a little easier to remember.
If you then take that answer (which is c.i.d) and divide it by 6, you will get cc's or liters. For example a 350 c.i. divided by 6 is 5833333 or 5800 cc's or 5.8 liter.......A 400 c.i divided by 6 is 6666666 or 6600 cc's or 6.6 liter. About as close as it will take you without being perfect. 350 chevy's are usually regarded as being 5.7 liter.
rossco said:This works better for finding liters from inches if you divide inches by 61. Ex: 350 divided by 61 = 5.73Blazin72 said:Another way to figure displacement is Bore x Bore x Stroke x # of cylinders X .7854
To find cc's exactly, multiply inches by 16.387 Ex:350 times 16.387 = 5735.
Normally, to find the static compression ratio of a motor, we will use cc's to calculate it. We would therefore use the volume of a cylinder such as a standard bore 350 as follows: .7854 times 4 times 4 times 3.48 times 16.387= 716 cc's in the cylinder.
