I just bought a 350 from a salvage yard to go in my 72 c10.It is stock with a casting # 3970010 on the block behind the left head.The stamped # on the right front pad in front of the head is gone.How does that #get removed?Maybe from a machine shop decking the top of the block?I found a red and white tag on the left side of the block under the head.The tag has no other name on it just REMANUFACTURED #394415.The heads have a 14014416 casting # on them under the valve cover.Mortec site shows them to be 305 heads uch!!!I have some camel hump heads #3782461 i could use on this motor.How much HP would i gain? I also have a Performer alumiumn intake i could use.How sick will the motor be if i use the 305 heads that are on it now?Please help!
