A higher stall convertor most directly relates to the cam you choose and where is the power band of the cam and motor.
Ex:
Edelbrock performer cam = 0- 5,000 = stock convertor
Edelbrock torker plus cam = 2500-6500 = you gotta have a higher stall convertor.
A higher stall convertor and a small cam can make a street car yuch....
The basic idea of a shift kit is, mostly by increasing and decreasing the fluid flow rate and pressure thru the valve body you change gears much faster. Same as ? shifting a stick with out using the clutch
Ex:
