I just installed a 9" in my 68 Camaro (100 miles ago)and i am dissapointed to say the least.It has 2 problems it has a bad whine when you are off the throttle or coasting,scrubs when turning corners (due to the trac-loc) i guess.I started out with a correct width housing bought a rebuilt trac-loc,new ring and pinion (Power Transfer Parts)/new bearings and crush sleve,new 31 spline Moser axles,disc brake set up,paid to have it set up, i have $2,000.00 in this thing.I have it out now and the Royal Purple gear oil (purple in color when new)is now brown and there is alot of fine gray metal material in the bottom of the housing.What do you reccomend?It also seems to have some vibration to it,the pinion angle is correct.
