What parts would I need to build a 500 horsepower 350 chevy. I don't want any forced induction. I want it to run on pump gas.
You don't understand not having an extra grand lying around? I wish we could all find that hard to understand.Why saddle yourself with the stock block? I have never, will never understand this. Get a Dart Little M or an SHP block. Throw down at least 396 cid. up to say 427cid. This gives you room to grow (I believe up to 454)
Save the numbers matching stuff for garage art until you sell the car. If you chuck a rod through your numbers matching block....good luck. Paint your little M block orange and 99% of people would never notice.
Yes its more money; the motor will have better manners, make more power, be stronger and give you the peace of mind that its not going to come apart at the seams. Good seasoned blocks with minimal coreshift are getting hard to find these days; and you want to avoid the thinner castings.
Or you could find a boatyard and get a 502 mercruiser motor; change the cam and intake and get awfully close to your goal
Oh I understand not having the extra grand. And perhaps the way I worded things came across harshly. I never intended to hurt anyones feelings. But I also know what happens when you have your heart set on something, say a 383 when you're in highschool. You take your block and get it prepped, you buy the heads you can afford, you laboriously micro manage everything to the n-th degree to the best of your ability. Then the motor breaks. You're out your block, and 2 con rods, several pistons etc etc. Now you can't afford to rebuild the motor and have to sell the car. Personal experience. It hurts awful bad and is pretty damn demoralizing to an 18yr old kid. I went through this with a few things until I learned there are some things that I personally won't skimp on. The better the foundation, the longer it will last and the happier I'll beYou don't understand not having an extra grand lying around? I wish we could all find that hard to understand.
This can be and has been done with a stock block, stock crank, even stock rods if you so choose. You can use stock lifters, stock lt1 pistons, and if you're really good a highly modified set of stock heads and intake.
Sure using all of that takes a lot of time and skill but if you have it it saves money. If you don't have time and skill it'll be expensive.
Exactly: My first concern is what kind of block you are planning on using? Can a stock block even withstand 500hp on a regular basis?Why saddle yourself with the stock block? I have never, will never understand this. Get a Dart Little M or an SHP block. Throw down at least 396 cid. up to say 427cid. This gives you room to grow (I believe up to 454)
This type of question gets asked several times a week. Invariably it involves a lot of bench racing among the 'regulars' as to how to "best" go about it. Best means different thing to different guys.What parts would I need to build a 500 horsepower 350 chevy. I don't want any forced induction. I want it to run on pump gas.
Whats the current compression? Why is the cc of the heads after they were milled? What is the cc's of the forged pistons? What do you have drive train related that will hold 500+hp? Do a twin turbo ls engine.I too, am trying to reach the goal of 500+ hp. I have a 95 K1500 (Silverado) that I'm turning into a "project". I have had the motor pulled, block bored 30 over, forged pistons, an "rv" cam installed, heads shaved slightly (though I am replacing them with Vortec heads - didn't plan ahead) and headers installed. I have dual 2-1/2" lines thru two high-flow cats into a Flowmaster dual inlet / dual outlet muffler, exiting duals out the rear. I also had the auto tranny replaced with a manual.
Unfortunately, the truck isn't running correctly. When under load and in high gear, I'm getting detonation. Could this be the heads? The more I read, the more I'm thinking it is...
My goal was to add a supercharger to achieve the approximate 500+ hp. What I lack in is direction, alas I come for advice from people that know all the in's and out's of this area.
Should I go for a better fuel injection (TPI / MPI) or stay with EFI?
Should I ditch the fuel injection and go carb? If so, at what cost to fuel economy? LOL I know, 500 hp and worried about fuel economy? Well, I do wanna maximize whatever I may get.
Should I look into stroking this motor?
Should I supercharge or turbocharge? The guy who did the motor seemed to think turbo so that it would only "work" the motor when needed, not like a supercharger would from start to shut off...
Long post, I know... just need a few answers and a place to start.
