i have never heard of this being done ,, i looked all over the board for this but i guess no one has done it ,, i got a 1973 ventura + 1969 camero engine bored .40 over and a t-400 engine from a 1989 chevy truck,, so i tried to mount the engine with 69 frame and engine mounts? its only like 1 1/2' to short!! i am stuck!!
Chevy and Pontiac motor mounts are different as you found out. What is to short? Don't understand, your using the Camaro frame mount, so the holes will NOT line up with the Pontiac mount holes. You may need to redrill the holes to mount the Chevy motor or weld in the new mount's to fit the frame.
naw the holes lined up fine ,, their was allready a 454 in it but it got removed and i got left with the shell,, ok i bought the frame mounts from a camaro shop,, and the motor mounts from autoparts store .both were for a 69 camaro
Or, you could take the '69 stuff back & trade it in for mounts & engine brackets for a '73 Nova with Chevy 350 engine. The '69 stuff uses the old-type mounting system with metal brackets on the frame, & the rubber mount on the engine. The '73 subframe should be drilled for the newer clamshell-type mount with the rubber on the frame & a metal bracket on the engine. This type is better if the rubber degrades, as the clamshell will keep the motor from lifting & accelerating unintentionally.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
